I took my 1994 C270 out yesterday for the first time to see how the diesel was going to perform. It ran smooth enough, but I found it did not take much throttle to get to 2800 RPM. My understanding is that this is the maximum cruising RPM for the Perkins M20. I could have gone over 3000RPM easily, which concerns me. Shouldn't the full throttle position be somewhat equal to maximum RPM under a load? It seems to me that I am either undersized relative to the prop, or something else is going on. I know I most likely have a dirty bottom, and probably the prop is all fouled with barnacles as well. I didn't get much speed at 2800. I will be hauling the boat in a couple weeks, and would like some thoughts on what others experience with the same boat and engine. What prop size are you using?
