E
Ed Schenck
This past winter I installed two cleanout ports on top of my H37C fuel tank. Got her really clean and then sucked new fuel through to Racor using oil extractor. But after she splashed I could not get her to run. Neither could the Yanmar mechanic(haven’t seen his bill yet). He wanted to replace all the fuel lines but I said no.Saturday I bought a 6-gallon poly fuel tank with the hose and squeeze bulb. Hooked that up directly to the Racor and bled the air from the primary filter and the injectors. You can put a lot of pressure on the fuel line with that bulb. The old 2QM20 started first crank! Then I used the oil extractor again to get fuel to the Racor. Put my thumb over hose, put it on the Racor and clamped tightly. Again she started on the first crank! And kept on running. Put it in reverse for some load and let her warm up for an oil change.I am assuming there was an airlock or other problem with that funny looking original filter, the one that looks like a metal can split in the middle. Should that can be removed? Is it a filter? I can bleed it from the bottom but otherwise it is inaccessible. I am considering keeping that tank aboard with about 3 gallons of diesel. But I hate taking up the locker space.
