Fuel venting hose
1
Oday Sloop Edgewater Yacht Club - Cleveland, OH
Hi - I've recently upgraded to a 30' 1982 O'Day from a 25'Catalina & we're new to having to deal with a diesel as opposed to the olde relaible outboard on the Catalina. We have been having some "fuel issues". When idling we have no problem but when we are out and throttled the motor up we have seen the motor "die" after about 5 minutes or so. My question here specificially revolves around the fuel venting hose. I removed the hose from its connection and found that it contained probably an ounce of "liquid", perhaps a mixture of olde diesel and or water. I removed the thru-hull fitting and found the two little screened venting holes to be about 90 - 95% clogged. I could barely blow any air thru them. After a thorough cleaning air was flowing freely. As we throttle up the motor we suck fuel from the tank, if air does not replace this fuel to equalize the pressure in the tank could this be one possibility of the motor dying?? As we are also treating the current fuel for possible algae and have also had it vacuumed, we are wondering what the likelihood of this vent hose being the problem after all. We have not been out for a sail since after cleaning the vent hose but we will give her a try tomorrow during Cleveland Race Week. Any thoughts???
Denise
congrats harv!
I have a 82 O30 too! You didnt' say which engine. We have a universal 5416 in ours. I think you will find that most problems are fuel related. we make it a point to change our racor filter, the primary fuel filter on the engine, and change the oil often. if the vent is funky you can be pretty sure your tank is too. Now After much staring at the tank I'm convinced it will be best to cut it up and remove it someday and replace it with a plastic tank. Fuel oil gets real nasty and a black sludge that is actually organic will coat the inside of the tank. the idle on ours wasn't good until we started using it more often. But again we make it a point to have new filters. Do you also have the facet fuel pump? Ours went bad but my son got it working again with a tap from a hammer! But we still installed a new one although not the same model. good luck with your new old boat!
