A few months ago I posted about a problem I had with fuel filling...had a lot of good suggestions on what the problem could be. Today I decided to do some investigating while getting the boat ready for spring launch. Did find some spider webs and other debris that I thought at first might be blocking the vent but on further investigation I decided that there wasn't enough there to cause a blockage. What I did find was a bigger problem. I've attached a couple of photos of the major culprit. I've not had any success finding the fitting shown in the photo. I've ordered an o ring kit in hopes that one of the o rings will be the right size.
The vent hose attaches to this fitting which in turn is attached to a nipple on the external vent. Not sure why they made it so complicated. To make matters even worse, the clam shell that covers the vent is glued to the fiberglass making it pretty much impossible to replace the vent itself. As you can see from the picture, the o ring has been destroyed...probably by somebody at he Hunter factory who wasn't very careful about the installation. Not only that,but there was a piece of flashing due to a bad casting of the plastic part that was blocking the vent (shown in picture). Good thing is at least I know now what my venting problem was caused by.
