Hi There, Well I am ready to start drinking...LOL. I pulled and removed everything you mentioned in your notes. Lifted the galley end of the tank to clear the floor opening, and pulling the cockpit end of the tank towards the galley. It is so tight that I fear I am going to crack the floor if I put anymore pressure on the tank. It is so tight even with the one end clear and coming out in the galley...it seems as if the cockpit end is wedge in the bilge to where I can move it ? I am not sure I want to reuse this sucker if it is this hard to get out, it needs to come out as it has brown mud in the bottom of the tank. I am thinking here...LOL. Larry Sent from Windows Mail From: groundhogSent: ?Thursday?, ?October? ?24?, ?2013 ?7?:?05? ?AMTo:
AlbinVega@yahoogroups.com
I did it while in the water.
I used a multiple purchase blocks from tank up to a 2x4 wood laying on companionway roof instead of tape. Rope under front end of tank.
Also, make sure you remove fuel fill hose which is hiding from view on the very back side of the tank.
Then, one other thing. The big round opening where the metal plate is screwed on....
That will try to catch itself on the aft floor opening edge and will drive you crazy. Get a really
thin piece of wood and stick it in between like a shoe horn so they slide by each other when
pass rather than catching.
groundhog
