I posted this over on the C310 site, but not getting any comments.
I'm wondering how others will view the effectiveness of this design?
Here is how I plan to improve my fuel quality. I'm convinced that I'm getting water in my fuel tank from the poorly designed vent. The vent in our C310 goes strait down to the tank. This is a poor design, it should first go up before it goes down to back drain any liquid water that may invade. There is also no provision to remove water vapor.
In my design there are (2) separate traps, one for liquid (a clear bottle that can be easily monitored) and one for vapor that will migrate through the vent saturating the fuel. I plan to use hygroscopic substances that are used to remove water from the air, called desiccants. These are readily available in packets that can be opened and poured into the hold. The traps will mount directly under the vent thru-hull in the aft port locker.
These questions become obvious and for me a pretty tough thing to answer, because of these variables:
How often will I need to change the desiccant? If not could it swell and block or restrict the air flow.
Will I have enough surface area in the desiccant trap to be effective?
How much air will be traveling through the trap over time?
How much fuel you're consuming over a season?
The difference in air temp causing a pressure differential turning over the free air?
As next season unfolds I will be monitoring the condition of the desiccant and will probable change my design based on my observations.
