Fuel Tank Valve
19
Beneteau 38 Slidell
Got a Beneteau First 38 1983 with fuel leak at the on/off value to the tank.
The brass fuel tank valve is labled " LB " ..." ??" connects to the fuel line with a leaking compression fitting to a 3/8" copper line. .
Can't find a compression nut for this valve anywhere !!. (I think it is 8mm ?? )
I believe it is metric.. w fine threads.
Anyone know where I can find the compression nut for this valve ?
Old stuff is hard to find parts for.
larryw
Jun 9, 2004
395
Beneteau OC400 Long Beach, CA
If it's the suplly side of the tank, just replace it with a length of hose, supported here and there. If it's the return side, take the fitting off and take it around to a truck parts outlet or an RV/bus parts place. They can probably match it.
