Fuel Tank Sending Device
76
Catalina 30mk cataumet Mass
I replaced the Fuel gauge this spring. When I turned the power on, it registered one time and then stopped working. How do I test the sending device in the tank? How difficult is it to change the old one out?
Thanks,,, Bobcat30
Feb 6, 1998
11,760
Thanks,,, Bobcat30
Place an Ohm meter across the center stud of the sender and the mounting flange. You should get a reading between 33 & 240 Ohm's
Aug 27, 2011
408
Catalina 27 Titusville, FL
You could also take the two leads and touch them together, that will cause the fuel gauge to read full.
I thought I had a bad gauge, buddy of mine told me to test it with this method, and lo an behold, the gauge was good, the sender was bad.
I think the two wires are yellow and gray. I don't recall if I took the one that was just pushed onto the ground position and touched it to the center terminal on the sender or vice versa.
Perhaps someone else can jump in on here and clarify.
Apr 5, 2010
565
Catalina 27- 1984 Grapevine
When I pulled the old sending unit out of mine it was almost discintegrated. Now I'm either full, which I think I am, or I'm getting a faulty reading. I had to dremel out a little half-moon piece to get the sending unit out, it's held in by about 8 machine screws on the top. Apparently the tank was slipped in as a complete unit during construction and they gave no thought to what owners years down the road would encounter in replacement.
Aug 27, 2011
408
I had a heck of a time myself swapping the sender out. I didn't cut the glass apart, but I did take the sender itself apart and put it back together in place. Tough 2 hour job...
Also on the 27...
Jan 6, 2010
1,520
My 1980 C30 had a tank top gauge from the factory. I used this for a number of years until I repowered.
I also replaced my old demure panel with the Admiral panel with all the bells-n-whistles. I put in a new sending unit and wired it to my panel gauge. Worked for less than a year.
Replaced it with a different make sender & it lasted less than a year. The wiring is correct, the gauge is good, & wiring so WTF?
I still had the old tank top model & put it back. I never have a problem. I have to move cushion & access cover to read, oh well.
Has anyone had this type of problem?
CR
Oct 5, 2010
322
Catalina 30 mkII St. Augustine
Capt Ron,
I had a similar problem and it turned to be a faulty ground.
Feb 6, 1998
11,760
CR
Buy an electric sending unit capsule for the tank top gauge. Other than WEMA senders these are the absolute most reliable sending units made.
A mechanical gauge, with the magnetic sending capsule is the Cat's meow.... It is what I use on my own boat... The sending units with the mechanism submersed in the fuel SUCK and are horribly unreliable. I will not install them for customers even if the beg...
A WEMA sender or mechanical with external sender are all I will use for fuel....
Jun 21, 2009
119
Catalina 30 Mk 1, #3335 Midland, Ontario
Maine Sail, do you have a make and model number for this sending unit? A supplier as well? West Marine (the most convenient place for me to shop where I live) has one. Thanks.
Feb 6, 1998
11,760
The Moeller mechanical senders look like this, your order by tank depth:
You then add this "conversion capsule" Moeller part #035760-10
Or you buy a WEMA sender for your depth tank. Moeller just re-sells the WEMA units:
You don't buy this style! This is a horrid piece of junk:
Jun 21, 2009
119
Ah, Thank You! And avail. at W.M. as well. As always, M.S., you are The Answer Man!
DanM
Mar 28, 2011
155
Catalina 30 Galveston Bay
Lots of great advice in this thread, but it reminds me of an old topic.
My C30 (#4328) probably has the sending unit that MaineSail hates, and it indicates more fuel when the engine is running versus when the engine is shut down. The only variable I can think of is the voltage (higher when the engine is running). Is the engine running voltage (higher) the reason for the higher reading?
Thanks! DanM.
Feb 6, 1998
11,760
Thanks! DanM.
Should not be, unless you have a faulty gauge. These senders are resistance readings not based on your system voltage... 33Ω is full and 240Ω is empty...
