relatively easy in our 1988 Catalina 30's
Replaced my 1988's a few years ago (5 +/-), mine had small pin holes possibly due to the fill-cap chain falling inside and causing galvanic corrosion.I had a local fabricator make a new tank from the old one, but they did make the tabs wrong at first, so the idea of getting it right from Catalina (Catalinadirect.com) sounds like a great idea.Removal was easy, just need to cut the fiberglass roving covering the tabs, disconnect the lines, and it will come out easily (obviously empty it, can remove the tank pick-up and pump it out from there, or use the fuel pump to pump it out by the engine).When I reinstalled the new tank, per the tank manufacturer, I added a neoprene rubber spacer between it and the hot water heater to prevent any galvanic action between the different metals and the electric current in the hot water heater.Then just used West's resin/glass weave to refashion the hold down fiberglass (even used the extra resin to reinforce the holding tank end plywood boards while I was doing it).If you need it, I have exact dimensions of the tank, just let me know.ALso, I have always wondered if I should have replaced the hot water heater at the same time (as to replace it would require removing the tank again).So, give some thought to doing it at the same time, given it is now 17 years old (get the stainless housing one for the extra $'s, worth the reliability and the non-ferrous metal housing).
