Jeff Dunham
Conducting normal maintenance checks on my 1981 H 30, I discovered the plywood deck that the fuel tank rest on was soaked with diesel. Since the tank is full, i visually checked for tank leaks and hose leaks but found none. I dried out the bilge and found no accumulation of diesel over a 7 day period. I am going to empty and then pull the tank to replace the piece of plywood. Will also look for a split in the filler or overflow hoses or tank hole. I am looking for any suggestions on how to strap the fuel tank back in place. It appears that banding material was the origional Hunter factory choice. Any other suggestions/experience?Thanks Jeff
