C
Chris
Hi- I have an Ericson 27 (1973) and I’m hoping to get some advice from other owners on a "new project"… I found a leak in the fuel tank for the Atomic 4. It's a hole about the size of the tip from a ball point pen. It's nearly impossible to see so reaching the hole for repair seems to be out of the question. The hole is on the side wall near the stern (and on the bottom edge of the tank). At this point my conclusion is that the tank must be removed, either to be repaired or replaced. But before I spend an entire weekend working on this I'm wondering if any other E27 owners have any helpful advice. I'm interested to hear any thoughts. A couple of my specific questions...1. Is it possible to even remove the tank? 2. Assuming it can be removed, should I have the tank repaired or replaced? 3. If it can't be removed, what to do? Any thoughts/advice would be greatly appreciated. Thank you,Chris
