Fuel Tank Pickup Problem
BadGuy
Mar 11, 2011
16
Hunter 34 Fort Myers
I have a 1984 Hunter 34 with what I believe is a stock diesel tank. This is a new boat to me and I discovered that it will only use about the first 5-7 gallons in the tank (and then effectively "runs out of gas"). I suspect the pickup line is broken/cracked inside the tank. I have not yet attempted to remove the pickup line to inspect nor do I know if it is even removable. I am wondering if anyone has experienced this. If so, how did you fix? Otherwise, does anyone have any words of wisdom? I would prefer NOT to do my typical of attempting to disassemble something and ending up with a $$bigger$$ mess on my hands. I half expect that there is a hard line inside the tank connected to the pickup "fitting" via a rubber hose. Is this correct?
Pictures or links appreciated!
Thanks!
Dec 2, 1999
15,184
I would try removing the fuel pickup tube from the tank. You are probably correct that it is broken/cracked and it is sucking air when it get below the break.
Oct 14, 2005
2,191
BadGuy...
While I have not had this happen to me, I have installed an access port in the top of the tank and cleaned it out several years ago. I found the pickup tube runs down to within about a half inch of the bottom of the tank in that corner. It's the low spot in the tank when boat is approximately level in the water. There was no pickup screen on the end of my pickup tube.
I would suspect that you could remove it and replace the pickup tube. If you remove the fuel shutoff valve from the square block (the 90 degree elbow at the tank top), you should be able to more easily remove the square block and draw the suspect pickup tube out with it in the process. I would put a wrench on the mounting plate that is attached to the tank to keep it from being loosened when you do this.
I'm hoping one of the other H34 guys chimes in with better info and experience with this problem.
Jun 3, 2004
890
Hunter 34 Toronto, Ontario Canada
Re: BadGuy...
Hmm. While I have spent several hours fussing around with my tank, I have not encountered this problem. A cracked tube sounds feasible, but I cant figure out how it could happen. Could it be some sort of pressure related problem- have you checked for a blocked vent?. I would also advise putting in an inspection port- either one of the commercial ones or a sheet of Lexan screwed and sealed as I did. You will be amazed at what you find in your tank if it is anything like mine was!!
Hunter 34 Alameda CA
It might have a crack as it is plastic. It is easy to remove as I discovered last September. There is a large nut that surrounds the tube as it enters the top of the tank. Loosen it and you can extract the entire length of tube. Probably have to take the fuel hose off first. You have to flex it slightly to clear the underside of the locker and this is where I believe it may have cracked from the last time it was removed. The tube probably has become brittle over the years.
If it is not cracked then maybe the problem is a clogging of the little screen that was crammed up inside the tube to act as a filter. After you pull the tube, look up in there for the screen. Best to remove it as your engine is protected by one or more filters with many feet of surface area as opposed to that little screen. This is a pretty easy job. The hardest part will be to bleed the fuel system afterwards. Lots of info on the site about how to do that.
Allan
Mar 25, 2010
152
Hunter 34 Rose Haven MD
I have not had a problem like this yet so really can not be of help. I have copied this into my fix it file for when I do.
I really gotta say as a H34 owner it is great that we have the ability to get help from each other knowing that it is the same boat and not someone telling you to tighten the bolt to port on top when you do not have any bolts on top!!!!!
Nov 6, 2006
10,058
I have not had that problem yet myself but I am interested ! I suspect that Allan is pretty close to the mark..
BadGuy
Mar 11, 2011
16
Thanks everyone - very good info.
I am sure it is not a vent problem as I removed the cap (used to check the fuel level) and the engine would still not run (until after I added more fuel).
Next time I am at the boat I will attempt to remove the pickup tube to inspect.
Thanks again!
rfrye1
Jun 15, 2004
589
Hunter H376 San Diego
An Idea
JD. It sounds like your issue is when you are motoring in calm flat water? What about your fuel filters? Are they fouling too? I assume you have changed them. You might have some gunk floating in the bottom of your tank that plugs the pickup when things are flat & calm. When there is motion, the gunk is stirred up and doesnt affect the pick up. Do you have a screen on the end of your p/u tube? those get plugged very easy. Might need to get the inspection port cut into your tank and have the fuel tank & fuel polished/cleaned. Living in the warm climate, algae & gunk will grow in your fuel, especially if you dont burn a lot and it sits in your tank.
Bob.
BadGuy
Mar 11, 2011
16
Re: An Idea
Hi Bob,
Exactly right - only happened (twice) when motoring in calm water. The filters are super clean.
The idea of something in the tank temporarily plugging the pickup tube is very interesting. No, there is not a screen on the pickup tube. I don't **think** this is the problem as adding fuel fixes the problem. However; I am certainly not going to dismiss it.
I am also reconsidering the vent line suggestion. My surveyor noted that there was a low spot in that line. I will resolve that issue too.
Thanks for the suggestions!
http://jdfinley.com
Oct 14, 2005
2,191
Bad Guy...
Follow your fuel line through the bulkhead to see if there is an old Perko water seperator in the fuel line, commonly attached to the fore/aft stringer or bulkhead near the shaft log. If so, there could be a vacuum leak at one of the hose clamps there.
I removed the Perko on mine and run the fuel line from the pick-up straight to the Racor. When opened, the Perko contained a lot of black "gunk".
Check the tightness of the Racor bowl to gasket also. I had one bulge and leak on me a few years ago.
If you find it necessary to clean out the tank, install a Sea-Bilt access port in the top of the tank after you've drained it. When I did it, the last gallon or so of fuel removed was nearly black with "stuff", justifying the labor and expense. Makes any future access so much easier too. See pic.
BadGuy
Mar 11, 2011
16
Re: Bad Guy...
Thanks Dan, will check that next time. Feel like an idiot as I didn't stop to think of tightening ALL of the fuel line hose clamps. I guess when I'm down in the locker getting out is about all I can think about. It is a VERY tight fit! :)
http://jdfinley.com
Apr 5, 2011
113
Hunter 34 Tilghman Island, Md
I had my engine rebuilt this past winter and when commisioning this spring it would cut off after 15 minuets. Turns out the leak was in the bleed screw on the engine block filter. If it isn't a vacum leak could it be the fuel pump is going bad?
Dan - what size hatch did you install on your tank & are there baffles in the tank?
Oct 14, 2005
2,191
Saillife...
If I remember, the access port I used was the 8 inch stainless one for a six inch diameter opening.
There are no baffles in these poly tanks.
