Fuel tank inspection port
Rob
Does anyone know where I can buy an inspection port / cover for my aluminum fuel tank? Thanks, Rob
Jun 16, 2005
476
- - long beach, CA
fuel tank port
Rob, I think you can buy those inspection ports at any marine hardware store. All you have to do is cut a hole, drill the screw holes, put some sealant around, use self-tapping screws and your set.
Dec 2, 2003
4,245
- - Seabeck WA
But don't leave the cuttings in the tank.
Be sure to run your fuel low and then clean all the mess inside the tank. Only then should you fit the port in place. But you knew that.
Rob
Starting Fresh
Thanks. I have removed the tank from the boat and will be cleaning it. The only port I have come across are plastic. Will these be sufficient? Do they make Aluminum ones anywhere?
Dec 2, 2003
4,245
- - Seabeck WA
You can make one
Plastic will work with diesel. That's what I use but you can have a shop make a oval plate that requires tapped bolts and a gasket. These aren't readily removable for inspections but are common. I've also seen a oval model that is pre-built with fasteners ready to go. I don't have the link though. Try google.
Jul 17, 2005
586
Hunter 37.5 Bainbridge Island - West of Seattle
If you want a aluminum one, here is a place
This is a heavy duty unit. You can use it on holding tanks, water tanks, or fuel tanks. I bought one for my holding tank, and it works great. But as I have said above, it is really heavy duty.
