Greetings! Have Hunter 30 (1983). Interested in replacing fuel sensor in tank. Does anyone have any info on the sensor (mfg, model, catalog cut?)
Thank you!
If you are interested in a electric unit, you can replace the tank float and wire in the electric gauge to the ignition switch. We did this on our HV'36.
Boat sensors for fuel, water, waste are notoriously inaccurate in either direction. I highly recommend removing the interior panel so you simply put a strong flashlight to the tank.
