Fuel Tank Gauge
8
Hunter 1983 Brooklyn, NY
Greetings! Have Hunter 30 (1983). Interested in replacing fuel sensor in tank. Does anyone have any info on the sensor (mfg, model, catalog cut?)
Thank you!
Dec 2, 1999
15,184
Check out Wema USA.
www.wemausa.com
If you are interested in a electric unit, you can replace the tank float and wire in the electric gauge to the ignition switch. We did this on our HV'36.
Jun 7, 2007
515
Hunter 320 Williamsburg
Boat sensors for fuel, water, waste are notoriously inaccurate in either direction. I highly recommend removing the interior panel so you simply put a strong flashlight to the tank.
