What a gorgeous week-end. Frost on the pumpkin at 6am and 75 degrees at noon. Needless to say, spent the day shedding clothes.
After finding unidentifiable items floating in the fuel filter cup and while replacing the fuel line, I decided to clean the fuel tank after 32 years of fuel storage.
I read the post in the Hunter owners mods, and decided to tackle the tank. I made a plate out of 1/8 aluminum to cover the hole when done. After emptying the 30+ gallons of red fuel with the hand pump, I removed the float and made the cut. Made a 1/2 starter hole and cut an opening about 8x10. Looking inside I found a thin layer of black residue attached to the sides of the tank. At the bottom, there was a small puddle of muck but below the pick up tube. After cleaning the interior properly, I installed the cover plate with a large rubber gasket and screws. I guess I was disappointed expecting to find other things (jimmy hoffa??). but I will feel better now approaching the jetties under power and heavy rolls.
I started refilling the tank with fresh fuel. The first 5 gallons indicated 1/4 tank on the gauge! although the tank is 40 gallons capacity?? I made a note with a sharpie on the tank. I will resume filling, 5 gallons at the time and marking the tank appropriately.
Now how to get that captivating diesel aroma off me. Clean clothes and several showers later, the Admiral still refuses to mingle with the crew.
