fuel tank alteration
1
hunter 456 passage portsmouth,va.
I am thinking about cutting a hole in the top of my fuel tank for inspection and tank cleaning. It would be like the hole for the fuel senser. I have a 456 and the tank is poly. I would like some feedback with pros and cons of this project . Thankyou
Jun 3, 2004
890
Hunter 34 Toronto, Ontario Canada
I cut a hole in my poly tank a few years ago for cleaning purposes. Easy cut with a uitility knife. covered with a piece of Lexan and sealed with Permatex. Screwed down every 1.5 inches. I can give you more detailed description if you need it.
844
Hunter 28.5 Tolchester, MD
Check Sea-Built access panels, which are purpose built for exactly what you seem to need: a clean out opening in an existing Poly tank.
I installed one 3-4 years ago; drained the tank by hand pumping the last bit of diesel thru the fuel line; drilled a 3/8" hole and cut a 4" diameter opening with a small saber saw; mopped out the tank and wiped it down internally with alcohol saturated cloths; Installed a 4" Sea-Built access panel and replaced the fuel lines and filters. Probably the same overall cost as having the fuel 'polished', but I had that tank absolutely clean including all interior surfaces and the fuel gauge float assembly, and can open the acess panel and check or re-clean the tank if it is ever necessary.The heavy neoprene type gaskets on the Sea-Built access panel will not react with fuel or additives...I wouldn't risk liquid type gasket sealers getting into the fuel system; just my opinion.
Jun 3, 2004
890
I forgot to emphasize that you need the Permatex product that is impervious to kerosene- blue tube I think.
Jun 4, 2004
844
Sorry, I checked my records and the Sea-Built access panel was 6" diameter, not 4".
An 8" diameter is available if you need a larger opening to access a larger or longer tank.
Oct 14, 2005
2,191
Wayne...
Here's what it could look like as done on my H34 with a Sea-bilt port and a Teleflex sender. The Sea-bilt unit comes with its own gaskets so there's no need for a sealant as per Richard's post. They ain't cheap!
You should empty the tank first to prevent any cuttings from getting into the fuel pick-up/filter system. Give the tank a thorough cleaning while it's open before putting the port in. Good time to get the fuel polished as it's being removed or while it's out of the tank. Use the lid as a pattern to drill the bolt-up holes.
The sender uint was mounted by drilling and tapping the poly tank and just screwing it down once its opening was hole-sawed.
No leaks from either installation over the past few years since done.
78
Hunter 34 Grand Lake
Dan
Did you get the aluminum or the stainless steel Sea Bilt port and why did you chose the one you did?
Jacques
Oct 14, 2005
2,191
Jacques and Neil...
Jacques: I chose the stainless port in the 8 inch size. I preferred the stainless over the aluminum one for strength and resistance to fuel. The size made it easier to get my arm inside to wipe down and clean out any and all the gunk from its 25 years of use.
Neil: Yes, the tank had developed the typical concaveness as can be seen by the staining residue to the rear of the access port in the pic I posted. The stainless port, when bolted up, eliminated the concaveness at the mounting, and drew up flat to make an excellent seal (another reason for the SS one being used).
Ivan
Hunter 356 Solomons MD
Choice of aluminum or stainless
FYI: The Sea Built site states that for a poly tank and diesel fuel you must buy the aluminum unit, not the stainless one. It apparently is a materials compatibility issue, not strength.
Oct 14, 2005
2,191
Ivan...
According to the Seabuilt literature piece I have, the aluminum one is for diesel fuel tanks ONLY. The stainless one is used for water, holding, OR diesel fuel tanks.
Neither one of them is for an installation on a gasoline tank.
On the literature's tank compatibility chart, both aluminum and stainless are considered "best" for the application. Nowhere does it say that it's not compatible with a poly tank.
It's possible that their evaluation has changed since I bought my stainless access port in 2006.
PS: A check of their website's compatibility chart now lists stainless as "OK" for a poly tank, but I still couldn't find any comment about not being compatible.
