I have a Universal M-12 and it appears that when fuel is pumped to the engine it goes directly into the fuel filter then to the injection pump and fuel that is not injected into the engine is returned to the fuel tank via return line. The electric fuel pump that feeds the engine from the tank runs continually when key is on. My thoughts are that the fuel which is not burned is continuously cycled through the filter. Could this be correct?
