I have been having an issue with fuel squirting out the vent when refueling. It squirts out the vent before it comes out the deck fill. I normally quit filling when i hear the deck fill noise starting to go up in gurgling sound... Here's the configuration:
-50 gal fuel tank is under quarter berth.
-Fill is on deck slightly aft above quarter berth -short run
-vent is on cockpit combing above fill
-fill line to tank goes into the aft tank vertical wall at highest pt.
-vent line is on top of tank and follows the fill line and goes inside cockpit combing above deck fill
-all lines and tank replaced a yr ago
Shouldn't fuel be coming out the fill before the vent? Filling is always as slow as the pump will allow. Today was the worst. Had fuel all over the deck and no indication in the fill line it was full. I'm not sure it is full. Since i replaced the tank with same p/n, should I shim the aft end up a little? But that creates stress points on the tank bottom.....thoughts?
