The Yanmar fuel solenoid is sticking according to 2 mechanics. The first Yanmar certified mechanic said it is an electrical issue as the solenoid is getting power all the time the key is on. It got hot and likely burned up which is why it works sometimes and sometimes does not. He's recommending we change replace the solenoid shut off valve, not a cheap option. But, if needed, we will get it done and by a certified Yanmar tech.
A second mechanic was also able to get the engine to run well but it would not stay running. He believes the solenoid is involved as the solenoid gets warm to the touch but is not certain it needs to be replaced. We are preparing to head north in a few months and need to feel confident in the resolution.
Has anyone heard of this and what would cause such a failure (simply asking to learn).
Thanks.
Thanks.
