Tom
I just finished replacing the fuel lines on my O'Day 34's Universal 24. The problem is the boat yard started the job, the tech was hurt and a car wreck after he had removed all of the lines and hasn't been back to work. I reviewed the owner's manual and replaced the lines. The problem is the fuel retrun line. The barb coming out of the last injector is small approx. 1/8 inch. The fittings for the return line at the tank are 1/4". Is there a reducer in this line to drop the attached line to 1/8 inch or is the 1/4 hose tighten to the barb? If someone could look at your set up next time you're on your boat and reply I would appreciate it. I know this is a dumb question but I want to get this right considering any leakage would be on a hot engine.Thanks.
