I have a Universal M-25XPB engine. Last year the wire for the oil pressure switch broke off. Not realizing the problem, I was still able to run the engine with no problems. Finally on a cruise the engine stalled. After being towed to a marina a mechanic repaired the broken wire. He explained that the oil pressure switch actuates the fuel pump. When I turned the engine key on I could hear the pump clicking. He claimed I was able to run the engine without the pump activating since gravity delivered the fuel. I had a full tank. When the tank was less than halve full gravity was not able to do the trick hence the stall. Now finally my question. Now,I do not hear the fuel pump clicking when I turn the key. Is this caused by a full tank and hence the fuel pump does not need to be activated? Or is the fuel pump always activated when the engine key is turned on?
