Fuel pick up tube screen H31
Frank;I had the same problem of the little screen at the end of the pick up tube being blocked. Here is what I did on advice from a mechanic. Loosen the nut at the fuel pick up tube at top of tank. Pull the tube out of the tank. Remove screen. Swear at it. Throw it away. When you are removing the nut, hld on to the top of the fitting so it won't slip away. Of course, i'll assume the fuel line is unattached and that you have turned the fuel line valve off. Carefully wiggle the tube out of the tank, remove screen and carefully put the tube back in and re tighten the nut. reattach all hoses, open valve and bleed all air from system , and you are back in business. If you haven't already a large fuel filter in line between the fuel tank and the engine, install one now. The little screen in the pick up tube serves no other purpose but to clog up and drive us nuts. That's why God and smart mechanics invented large filters for us to install. Hope you are not claustrophobic as you have little space to work. regards, Mac Lindsay 1984 H31
