While motor sailing my diesel stopped running. I checked the primary filter
and found quite a few pieces of gunk but the fuel bowl was full of diesel
and the filter was clean.
I checked the secondary filter and it was clean and the bowl was full of
diesel. I assume what happened was my fuel tank is full of gunk and
my fuel pick up tube has a screen and a large piece blocked the flow
and sucked air into the system. When I bleed the air out all was OK.
Not sure where the air came from as I had a full tank.. My questions
are:
1. any ideas where the air came from?
2. when I get my tank cleaned should I have the yard remove the
screen?
are:
screen?
