I have a Universal M-18 diesel engine in a Catalina 27. I changed the oil recently and noted that what I think is this electric fuel lift pump feels hot after running the engine for a couple hours. It doesn’t feel as hot as the radiator cap or engine thermostat to touch but is hotter than what I could continue to touch for more than a few seconds. As best as I can this looks like a Westerbeke fuel lift pump. I can’t find a manual online for it. Other fuel pumps i.e. found on Catalina direct describe operating temperatures of -40F to 180F and I don’t think it gets hotter than the engine at about 165F. I don’t suspect contaminated fuel or plugged fuel lines since I cleaned out and pressure tested the fuel tank and replaced the lines from the tank to the fuel/water separator about 8 months ago in looking for a fuel leak (which hasn’t happened since I replaced the fuel line).
Should I be concerned about the pump feeling hot?
