Yanmar 2QM15 was working fine at the end of the last season. I was all set motor over to haul-out and paint today, but couldn't get the engine to start-up. The only change from last year was the replacement of the fuel pump (attempt to prevent future problems). I have bled all the air from the lines (as I've done many times before). I'm certain the new pump is correctly installed because fuel pours out of the fuel filter bleed screw and injector nuts when manually pumped and when cranking by key. I noticed the fuel was rather cloudy so I pumped-out all but a few ounces out of the tank and replaced with 10 gallons of fresh diesel and changed the primary and secondary fuel filters. Still no go. In frustration I pulled the old WD40 trick and sure enough the engine runs like a top when receiving WD40 straight through the air intake. My only belief is that the fuel is still bad, or that it's time to inspect/replace the fuel injectors. Any ideas???
