Rob
I would like to upgrade our fuel gauge system. Currently we have 2- 50 gallon aluminum fuel tanks. gravity fed. The current gauge are dip sticks. these dip sticks , 1 per tank , are alum tubes. to check the fuel, I unscrew the bolt head, pull the dip stick wipe, off and redip and check the level. besides being in a difficult place to get to, (inside the base of a cabinet, behind the port and starboard setae' 90% of the time Im required to move things).....they are also tough to read. with my glasses on!, and the light just right, I can see what is wet and what is dry...not a high confidence builder... checking the fuel, is the longest part of pre check before we fire the girl up.Im looking into a backup gauge system. Keeping the dipstick but also adding a readable gauge at the nav station. I was looking at the Tank Tender air system or maybe snake river gauge systems....I like the tank tender idea as there is no electricity required to hook to the fuel tank.I would like to ask the group what they recommend, what they would stay away from and what you use on your boat.ThanksRob
