Fuel Gauge
jfp737
Jul 10, 2006
16
Catalina 30 Tall Rig Milwaukee
Our newly purchased Catalina 30's fuel gauge doesn't work. (just like me on weekends) Is it an easy fix? Sending unit? or the gauge in the cockpit. Thanks, John
Search on fuel use
One good one is Why do you need a fuel gage?
Don
Troubleshoothing fuel gauge
Most factory installed fuel gauges are made by Teleflex Marine. Try this link for a simple troubleshooting guide.
Dec 2, 2003
480
Catalina C-320 Washington, NC
According to the Seaward techies...
The most frequent problem is a short or break located in the wires between the tank and the gauge.
jfp737
Jul 10, 2006
16
why a fuel gauge?
Why do you think? Why was it installed in production?
They put 'em in because people are
used to them in their cars. There was a time (well before mine, I must not only admit, but demand *5) when all sailors had was a dipstick to measure fuel level. The difficulty with fuel gages, besides their recurring in-operation, is that many tanks are thinner at the bottom than the top, which gives a false sense of security because the level between half full and empty goes down much faster. Given the problems with senders, wiring, gages and the like, I've just calculated my fuel use over eight years and know we use less than 1/2 gallon per hour of engine run time. I fill up with 10 gallons every twenty hours. We have a 23 gallon tank. It's not that hard. It depends on the engine hour meter, but, heck, that still works and is much easier to replace than a fuel tank sender.
- - Channel Islands harbor
I recommend a new sending unit
My Catalina 30 fuel sending unit didn't work either. I bought a Telex (?) replacement at WM for less than $30. It wasn't at all hard to replace (good instructions) and, for me, well worth it. It worked without a problem and was accurate, and I highly recommend one.
