fuel gauge on when main circuit is turned on?
114
Catalina C27 - Tall Rig Door County, Wis
We have a 82 Catalina,got her home today from her frozen in marina up north and running threw the electrical .
My son noticed the fuel gauge go on when main power was turned on,engine key is in off position and not in accessory or run just off.
I took a lookski and the terminal for the fuel gauge is run to a always hot connection on the ignition instead of the run side.
My take is this is not right and should be changed any one thoughts ?
Thanks!
May 11, 2005
3,431
Seidelman S37 Slidell, La.
Sounds like
Sounds to me like you just have to move the fuel guage terminal wire, to a switched terminal. This was more than likely simply installed in error.
Beneteau 323 Annapolis MD
For SOME reason it has been wired this way and at least it works. If you don't like it, move it :doh:
Feb 6, 1998
11,772
Just move it from one side of the ON/OFF switch to the other..
