I’m noticing a strange reading. I have a teleflex gauge and a Wema vertical sender. Both 30-270 ohms or whatever the correct numbers are. It’s been working fine until...I repowered..The tank is a fifty gallon tank under the quarter berth with the sender in the forward end. During the repower, I had to rewire the whole fuel gauge circuit. The tank is “full”. Before the repower, the gauge read full. Right at the upper mark on the face scale. Now, the needle is almost pegged. All wiring/grounds etc are correct and good. So, I deduced that since the new engine is lighter and the boat is a bit bow heavey, and the sending unit is forward in the tank, that maybe the float is “higher” than full. Is that possible? A full reading is a 30 ohm circuit. Does that mean a pegged needle or the end mark on the meter scale? Now, the kicker is, I disconnected the sender wire from the gauge and measured 55 ohms between the wire and ground so the reading should be somewhat below “full”. I, again checked all connections, grounds, and even substituted wire runs. But, to get the gauge reading correctly, I need more resistance. Something is not making sense...
