Hi all:
I don't know how many of you use Shell fuel for your (car)
and boat. I used Shell gasoline for my cars and diesel for
my Vega- unfortunately! Because it has been determined that
Shell fuel will damage your car. Both of my cars now need
major repair! Nothing has been said so far about diesel
fuel.
For the last few weeks my diesel engine became hard to
start. I changed all the filters, but the situation became
worth! I checked everything and found out every connection
for the fuel supply was leaking. I tightened every leaking
connection, but to no avail! Upon inspection I found every
washer or gasket in a deteriorating condition, either
corroding or disintegrating. With air in the line, a Diesel
Engine won't start! I needed to bleed the lines every time
before starting the engine! And after the engine ran, I
found new leaks!
I'm now in the process of pumping out my fuel tank,
replacing with another brand of diesel fuel, and installing
new washers and gaskets for the fuel supply line.
Question: Has any one of you had a similar experience?
(with Shell Co. diesel fuel).
Wilhelm, V-257
__________________________________
Do you Yahoo!?
Friends. Fun. Try the all-new Yahoo! Messenger.
fuel.
found new leaks!
Wilhelm, V-257
Do you Yahoo!?
