Fuel from dock or gas station
May 7, 2014
135
Beneteau 390 Tiburon
Other then maybe tax is there any difference in buying your diesel fuel from a car gas station or marine fuel dock?
hewebb
Oct 8, 2011
329
Catalina Catalina 25 Joe Pool Lake
I use Jet-A from a local small airport. (A lot of local airports have self-service so it is easy to get) It is more stable and will last a lot longer. I have no idea what the difference in blend is between dock and service station diesel. I do know that in my truck bio diesel blend, which most stations have now, gets less mileage.
7,727
Alden 50 Sarasota, Florida
Other than the dye which differentiates the road tax charge, there is no difference except the marketing which implies additives included which, if done at all, are made at the refinery, not the distribution point.
Don's right, your boat, your wallet, you choice. Transferring fuel is sometimes a hassle for some, try Google: Super Siphon.
Dec 3, 2013
169
HUNTER 29.5 PORT CHARLOTTE FL
As I understand it, Jet A is kerosene w/additives to prevent congealing at altitude (low OAT). I would be concerned about a lack of lubrication of the injection pump and other parts.
Do you use Jet A in both your truck and boat?
FWIW... My boat is some distance from a fuel dock so I purchase 'off road diesel' and carry it to the boat.
