I need to remove the flexible hose on this fitting on top of my fuel tank. Unfortunately the tank was installed during construction before the boat was closed (Legend 35.5) and this is in a awkward place at the stern of the boat. I do not have access to the 2 stainless collar screws so I can not remove the hose from the fitting. At the base of the metal fitting there is a large nut. Can I remove the fitting from the tank, with the hose attached, by unscrewing this large nut ? I fear that something might fall inside the tank... If anyone has an idea it would certainly help. My project is to replace the rotten plywood under the tank and I would like to move the tank from side to side but the hose is too short so it needs to be removed.
