Thoughts on fuel filtering
Generally, my feeling is more is better. The Racor I installed is WAY, WAY oversized. Restriction in an otherwise properly engineered and functioning system is generaly caused by "stuff" filling the teensy weensy openings in the element. To elininate the problem. go for a same size element with a larder particle size rating, ie: 10 micron vs. 2, or go for a much larger volume element with appropriate housing to the finer rating. That was what I went for, and have had no concerns ever since. For additional peace of mind I spliced in a low pressure (2 1/2 psi) electric pump fuel (Pep Boys, about $30) between the tank and the Racor. There is of course, a coarse, in-line strainer-filter between the tank and electric pump just to make sure none of the big nasties get to the pump. The pump simplifies bleeding the system, and the way I have it set up I can use it to recirculate fuel through the Racor and back to the tank or use it to empty the tank. The OE Yanmar 2 micron filter is still in line on the engine as a backup, but since installing the Racor I've never seen anything in it when replacing it and that's just the way I like it!
