Fuel filter
Jul 2, 2016
3
Hunter 28 Rogersville, AL
New to me Hunter 28. Fuel filter on engine calls for a Yanmar 55710, which I believe is a 10 micron filter. Also, have a Racor filter between fuel tank and engine. Model is a 110 and manual says to use an R11S which is a 2 micron. Is this typical? Thanks
Apr 22, 2011
922
Hunter 27 Pecan Grove, Oriental, NC
Generally the filter on the engine will have a finer element than the primary filter. The Racor model 110 can be used as a primary or secondary filter in that it can work on the suction or pressure side of the fuel pump. A 10 micron element is available for the model 110. I would opt for that instead of a 2 micron.
Apr 13, 2015
157
Catalina 309 Port Charlotte
The racor would be the primary filter. I too would not use a 2 micron there. The S in that filter model stands for "secondary", that's why it's 2 micron.
Dave
Not really, Dave.
RACOR FUEL FILTER NUMBERS
From the Racor 220/225R Spin-on Series Manual:
R24S 220R, 2 micron replacement element
R24T 220R, 10 micron replacement element
R24P 220R, 30 mciron
R26S 225R, 2 micron
R26T 225R, 10 micron
R26P 225R, 30 micron
S - 2 micron BROWN; T - 10 micron BLUE; P - 30 micron RED
Beneteau 323 Annapolis MD
[QUOTE/// RACOR FUEL FILTER NUMBERS ...From the Racor 220/225R Spin-on Series Manual:
...[/QUOTE]
Model 110 is a cartridge, not a spin-on. Yeah, use the 10. I have the 3YM20.
Gunni
Mar 16, 2010
5,937
The Racor filter ID convention extends to the Racor 110 cartridge filters (per Stu's post) - S is 10 micron, T is 10 micron.
