Have a new-to-me 1988 O'Day 302 and the engine care by the previous owner wasn't exactly according to the owner's manual. Replaced the impeller, air filter and changed the oil in the crankcase and the gearbox this weekend. But between the diesel tank and the engine is a glass Racor (sp?) fuel filter. The filter is filled with some bad gunk. Is this a difficult task to replace? Is it as simple as unscrewing the current filter and replacing? Or do you need to bleed the fuel line during the replacement process? The engine runs great and I hate to monkey with it -- but the filter looks pretty bad.The engine is a Yanmar @GM20F. Thanks for your suggestions and comments.
