I added a (primary) Racor filter on my 1982 H33 in 2002. I check the sediment bowl frequently but haven't seen anything in it yet. Since I use only 10 to 15 gallons per season the filter can't be getting much use. The rated flow rate is much larger than the 2GM would use, so again the filter can't be very "used".I add a little Bio-Bore to keep bugs out every time I add fuel & haven't had any problems. Since the Racor is a 2 microns and the yanmar (secondary) filter is a 10 micron I can't see how the Yanmar filter could ever get plugged. My question is how long can a filter last under ideal conditions? Why change it if it's not dirty? Anyone have a problem with a "clean" looking filter clogging up?
