no way to prevent it.
Barrie:There is no way to prevent this. The engine has a built in thumb pump on the starboard side of the engine. You can actually pump fuel all the way from your fuel tank, fill the primary filter and then fill the fuel system all the way to the injectors with this pump.To make the job a little easier, you can prefill the primary filter with fuel. You should also have a fuel shut off between the tank and the primary filter. If you turn this off before you open the system, it will make the priming easier.
