Fuel fill hose/elbow
G
Geoffrey Kloster
three quetions will post separately. I'm installing a new fuel tank. Little space between tank and deck make for a tight turn in the fuel fill hose. Are there any 90 degree elbows compatible with diesel fuel? How tight a turn can I make with 1 1/2" hose? Thanks. Geoff
Jun 13, 2005
559
Irwin Barefoot 37 CC Sloop Port Orchard WA
Any of the metal plumbing fittings are OK for Diesel
You might prefer Bronze or Brass. If your tank is stainless or aluminum you could use that, and if steel you could use galvanized iron (not normally recommended on boats), and even that used inside and under-deck will work OK for many many years, even if it rusts somewhat on the outside. I had galvanized fittings on a home fuel oil tank for over 25 years within 15' of my sea wall (salt water). They (any metal) will also all work on a fiberglass tank. If you try to bend 1&1/2" fuel hose, remember you will probably (if you are coming off the top of the tank) have to make 2 turns or an S curve. How much room that would take, depends on the horizontal distance between the tank out let and the deck fitting. Good Luck Joe S
G
Geoffrey Kloster
Thanks...
That helps. I've got about 10" above the tank. It's a poly tank with a filling barb about 3" high. I think a turn in the hose would put a lot of force on the attaching barb. I'll try and find an elbow. Geoff
