Fuel fill dipstick
SqPeg
Oct 2, 2014
36
Hunter 32 Vision Bohemia Bay Yacht Harbor
My Hunter Vision fuel fill will not allow a straight dipstick. Any suggestions?
May 24, 2004
7,174
CC 30 South Florida
Know your usable fuel tank size, install an hour meter, calculate your burn rate (GPH), and keep a log of hours at every fill up. If you know the hours you have ran since the last fill up and your average burn rate you can calculate how much fuel you have used and how much fuel you have left. It is very accurate and useful when calculating range. After a little practice a look at the hour meter will give you available fuel. A stick is accurate but hardly easy to do when underway. More accurate than a fuel gauge. Hour meters are inexpensive and serve to keep maintenance schedules, trip logs and other purposes.
Jan 7, 2011
5,627
Oday 322 East Chicago, IN
Carry some extra diesel.
Top off every few weeks (depending on usage)
Install one of those external-mounted tank sensors.
Greg
I just installed a Wema fuel sensor in my 89 gallon odd shaped diesel tank. http://www.wemausa.com/
Plug n Play install. Gives relative fuel level in tank to external gauge. Works alongside my fuel log.
