Fuel Consumption
Dan R.
I'm buying a 1979 Catalina 25 with a mid 80's 7.5 HP 2 stroke outboard. I'm trying to get a general figure on what fuel consumption rates I can expect. I'll be sailing from Norfolk to Annapolis later this month (against expected prevailing winds) and am just looking for a ballpark figure so I'll know how much fuel to keep onboard in case I spend many hours motoring in one day. Thanks.
jimg
Real world experience. Lots of different 2 stroke outboards on several different sailboats: With the combination you mention, I would plan on slightly more than 1 gal. per hour at full throttle, better mileage if you back off a little, and without much effect on boat speed.
Joe White
Fuel Consumption - 2 stroke
I have 1984 25.5 Hunter. It had a 9.9 2-stroke. I replaced it with Mercury 9.9 4-stroke. At about 75% of maximum RPM I get about 5.5 knots with 1/2 Gallon per hour. I carry 2 tanks of 6 Gallon and a spare 3 Gallon. I have never used more than 3 gallons on any trip.
Mar 1, 2005
220
Hunter 34 North East, MD
Prevailing...
winds on the Bay are generally from the southwest. After a cold front we usually get northwesterlies. A coastal storm off the Carolinas will throw in easterlies before going northeast (then you'll need the OB). All the others mean you should have a romp up the Bay on some form of reach and not need to use the OB except to make harbor.
muised
Aug 17, 2005
97
- - Halifax, Nova Scotia
My experience
Last summer delivering my O'Day 25 on the Atlantic coast, all motor: 48 miles 10.5 hours 50-52 liters fuel 8HP Yamaha Long Shaft (1990) Fuel consumption is quite a bit higher when you run the motor full out.
Simple answer
2 stroke about 1 gallon per hour (from our 1981 C25 with a 7.5 hp 2 stroke)
