Thru-hull drain hoses
I know you said you checked the thru-hulls. I had a constant leak below the port side cockpit area. After many hours of trying to track it down I finally located the culprit. It was my sink drain thru-hull hose. It had a crack in it right at sea pressure head and water was slowing flowing out of it and down the backside of the hose, collecting in the aft bilge area.
