Frozen aluminum sheaves
Jun 14, 2011
277
Hunter 22 Fin Keel Lake Martin
I've got in mast halyards and I've found 2 of the sheaves in the mast are frozen.
I was able to remove the mast base with the sheaves but is there a good way to free these things up? I'd rather not be destructive and the budget is getting thin for this years recommissioning.
Thanks.
Some pictures of the problem.
Aug 16, 2006
281
Ericson 32 Oregon coast
WD-40 left on it overnight should do the trick. Some
people like Inox better after you free it up. They claim Inox is more durable as a preventative lubricant than WD-40
Nov 9, 2012
2,500
Oday 192 Lake Nockamixon
I think you'd want to get the corroded aluminum out of there. PB Blaster probably won't do that. I wonder if you could use some oxalic acid on that. Or is that too strong, would eat away at the remaining good aluminum?
caguy
Sep 22, 2006
4,004
I'd soak them in vinegar or CLR for a couple of days. If that did not work and the sheaves are aluminum I would try a little heat. Good luck.
Dec 2, 1999
15,184
I would replace them after removing them. Rigrite probably has what you need.
Jan 6, 2010
1,520
I agree with Steve, somethings age to a point it would be wise to replace them.
That being said, just for piece of mind, remove them & take to a local machine shop for reconditioning. They have better equipment for this.
I still agree with Steve in replacing them. Do it right, do it once.
CR
caguy
Sep 22, 2006
4,004
Nice referral. I'm having trouble finding the sheaves pins. I replaced the sheaves on my traveler but had to use screws. I'd rather use the original rivet type. I couldn't find them at their site, unless they have a different name than sheaves pin. I can't found their prices either. Thanks for the lead, I have a lot more blocks in my garage that need repairing.
Jul 23, 2013
487
1981 Catalina 22 #10330 Bayview, ID
I would replace them with something made with synthetic materials so that it doesn't happen again. If you seldom unstep the mast, you'll probably never know when it happens, like this time. Ronstan makes a wide variety of sizes.
I recently replaced mine and, although the sheaves were only worn out and not frozen, the pins were. I'll probably publish a post about it on my blog this weekend. There's a link to it in my signature. The main point of the post will be about replacing them with oversize sheaves. Not exactly the same thing, but it might be helpful.
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
most of the manufactures have a reffing service and can rebuild them just contact them and see what they can do for you ...
regards
woody
Dec 30, 2013
56
ODAY 322 Portsmouth
Same issue with my furler sheaves. (They had a removable pin so it was easier to pull) My local hardware store had new bronze bushing, 'pressed' them with my bench vise, cut the excess and smoothed the edges and they fit right back in.. If you can get the right sheaves and pins you could try drilling them out and replacing the axles.
Pat, 'Blue Skies', Portsmouth NH
WADR, why? Rivets: not repairable, if stuck they have to be drilled out.
Bolts and bushings: easily replaceable, sheaves are easy to replace and lubricate.
Sep 4, 2005
6
- - Sausalito
Soak them twice
Soak them first in Kroil or P/B Blaster until you can work them free back and forth and then eventually turn them freely. If they are especially tough to move use a piece of line, or wire halyard, around a sheave with a cable clamp to grab it tight - to form a handle. I personally would gently use a pair of channel locks to grab each sheave to get it to start turning if I had to - but you may not want to. Even though a rat tail file would smooth off any rough spots later. <g>
Then, if it were me; I would soak them in a melted blend of paraffin wax, motor oil with teflon in it, and Never Seize. Let them sit in the warm/hot mixture for a few hours and then hang them up to drip dry and cool. This is what I now use on non o-ring motorcycle chains as you can't get chain boiling grease any more.
PHM
Thanks.
