On my recently purchased Catalina 22, I noticed that the roller on the front of the trailer was deformed and almost cut in half, so I replaced it. After a couple of month of trailering, the new one started to deform as well. So I tried to loosen the bolt that holds it up against the hull to lower it a little bit. The bolt snapped very easily. After a little work with an EZ Out (that also snapped) I sawed the nut off to remove the rest of the bolt.
So here is my question: How much weight should rest on this roller? Once I re-weld a nut on, how do I determine the proper height for this roller? Is is really supposed to hold any weight at all?
