Frig control not turning
May 9, 2014
10
Beneteau 31 Bethel Island
I have a 2001 Beneteau 311 and the control knob on the frig does not turn. It shows numbers from 0 to 7, but does not turn. I am afraid to put a wrench to it but might have to. Anybody have this issue?? Or have suggestions? Thanks
Beneteau 323 Annapolis MD
If it doesn't turn anyway, why not try? It should have just a little resistance to turning. Maybe the contacts have corroded together, in which case you'd need a new one anyway.
Jun 21, 2004
2,887
Beneteau 343 Slidell, LA
Had the same problem when I purchased my 343 couple years ago. The control was totally corroded. I replaced it and it lasted about 18months before it rusted again. ( The frig stays powered up continuously). On the second replacement, I sprayed CRC anticorrosive liberally on the inside of the control and make a point to turn the knob once a month to keep it working. The replacement control knob / thermostat for my Isotherm frig costs approximately $75. You would think that the thing would at least last a few years.
May 9, 2014
10
Very helpful information. Thanks for the details and response. Hope your frig hangs in there longer this time!!
