Fridge Drain
Jul 5, 2019
2
Beneteau 423 St. Augustine FL
We just purchased a 423. The drain in the fridge backed up and stunk! Fixed that but any suggestions for us to deodorize.
Thanks!
Aug 27, 2014
91
Beneteau 373 San Diego
Likes: cece721
Dec 31, 2016
319
Beneteau Oceanis 351 Charlottetown
A gallon or more of vinegar, it takes a bit longer, but causes no harm to your system.
RoyS
Jun 3, 2012
1,742
If fridge is electric that drain should usually be plugged closed with some sort of stopper. If it is an ice box then the drain should have a trap to prevent cold air from dropping through it.
Likes: NYSail
Dec 31, 2016
319
My 351 uses the same pump as the bilge, crossover switch for one or the other under the starb side
NYSail
Jan 6, 2006
3,178
Beneteau 423 Mt. Sinai, NY
Clean the filter out then carefully pour vinegar directly in drain from refrig side and pump through hose to sit.... pour a little in freezer drain..... again just let it sit. I find the drain sucks and water will flow right out of fridge when a lot of water is introduced.
Once cleaned properly it will be fine
Good luck!
Greg
Likes: BrianRobin
