Freshwater Pump
Ron M
Mar 21, 2010
67
Beneteau 331 Rock Hall, MD
Just last week we just purchased a 2003 Beneteau 331. During the survey the freshwater pump worked flawlessly. However, during the delivery trip, when the water was NOT in use it began cycling ON momentarily about every 2 minutes. Any thoughts?
May 19, 2009
22
Beneteau 323 Ipswich .. East Coast
Hi ..
We have a 323 .. If its out of water the pump runs all the while .. If you have a leak then the pump is just pumping up the pressure .. It may be a leak in the pump .. Ours is a Jabasco and just has a simple rubber diaphragm pump so rubber leaking ..
Try tightening the 4 screws that hold it together .. Change it .. Check all the pipe connections including the shower on the back .. They break if frozen ..
May 25, 2004
446
Catalina 400 mkII Harbor
i could also be a leak from the supply tank allowing air into the system.
mike
DougM
Jul 24, 2005
2,242
Beneteau 323 Manistee, MI
The pump shouldn't cycle unless there is demand. The tank is on the low pressure side of the system and probably isn't air tight anyway. I would look for a loose fitting or a drippy faucet. Worst case would be a line or fitting that froze and split...
Did you check for an unusual amount of water in the bilge?
Nov 23, 2009
437
Beneteau Oceanis 361 Clipper --
Check if there's a leak from the accummulator tank. There could be a very very thin crack, not so easy to spot, but enough to cause these symptons.
