Freshwater Anode Magnesium
Daron
May 7, 2019
3
Hunter H27 LKN
Hi, my 82 Hunter 27 with a yanmar 1gm is on a freshwater lake in NC. Does anyone have ideas to use a magnesium anode for this engine. I read that zinc is not really effective for freshwater. Any ideas or advice??
dLj
Mar 23, 2017
5,193
That is what is recommended for fresh water. You are on the right path.
dj
Daron
May 7, 2019
3
Hunter H27 LKN
Thanks for the reply. It does not look like Yanmar or boatzincs.com makes a magnesium anode for the 1gm. Anybody make a diy magnesium anode??
Jun 21, 2007
2,118
Just to clarify. Are you asking about the anode that actually mounts onto the engine? Or about the anode that mounts to the prop shaft?
Firstly, a disclaimer. I am not an expert on this topic.
If the engine does require a anode in lake water, it is probably a large diameter pencil zinc that screws into the mounting plug. This will be a generic item. Not necessarily Yanmar specific.
As this is a "every engine", question, rather than "Yanmar specific", maybe to go to the local ski boat engine repair maintenance shop and ask their opinion. Or call up these folks:
https://www.boatzincs.com/engine-magnesium.html
Marine grade aluminum anodes are also approved for fresh (lake) water. Likely likely would be able to locate one.
Lastly if your 1GM engine is anti-freeze cooled, rather than raw lake water, an engine anode definitely is not necessary.
