What is the best way to keep fresh water pure in the water holding tanks for extended periods of time?
I think you'll find that those are from your water heater. The aluminum tank starts to corrode and suffer from electrolysis. You might start by putting a filter downstream from the water heater. Just be sure it is accessible. Also, check the water heater to see if it is leaking. That's an early sign. A vinegar flush ;-) might help and won't hurt.The filter catches the small "rocks" before they get to the pump, but they constantly clog the filter. Fill it with vinegar? Muriatic acid diluted with a quick flush?
