Fresh Water Tanks
2
Beneteau 351 Marina Bay, Ca
What is the best way to keep fresh water pure in the water holding tanks for extended periods of time?
Dec 2, 1997
8,950
- - LIttle Rock
Two things...
1. Recommission the system annually (instructions in the archives...search for "fresh water")...and
2. Use and replace your water frequently
Also...before filling tanks, let water run long enough to purge all the water out of the dock supply line and your hose. You don't want to put water that's been sitting in 'em in your tanks.
Jun 7, 2004
383
Schock 35 Seattle
I borrowed a trick from the RV crowd and filter all the water going into the tank. Always stays good tasting.
Nov 11, 2009
3
Hunter 42 Passage MDR
Salt Deposits in Fresh Tank
Any suggestions how to get rid of salt scale in a fresh water tank? Seems some salt water must have gotten into my tanks at one time or another. The filter catches the small "rocks" before they get to the pump, but they constantly clog the filter. They also significantly cut down on the flow rate coming from the tank. A reverse "blowing" air into the tank dis-lodges them for a while, but eventually....bunch of rocks in the filter again. My tank is an older (1990) stainless tank. No way to just open it and clean it as there are only small holes in the top to fill it and vent it. Fill it with vinegar? Muriatic acid diluted with a quick flush?
Rick D
Jun 14, 2008
7,186
The filter catches the small "rocks" before they get to the pump, but they constantly clog the filter. Fill it with vinegar? Muriatic acid diluted with a quick flush?
I think you'll find that those are from your water heater. The aluminum tank starts to corrode and suffer from electrolysis. You might start by putting a filter downstream from the water heater. Just be sure it is accessible. Also, check the water heater to see if it is leaking. That's an early sign. A vinegar flush ;-) might help and won't hurt.
Oct 22, 2008
3,502
- Telstar 28 Buzzards Bay
Also, use opaque hoses and minimize light exposure to the water system.
Nov 11, 2009
3
Thanks for the replies. I think there may be 2 problems. 1, the salt "rocks" in the pre-filter are definately coming from the holding tanks as i have an inline filter coming right off the tanks. However, i dont have one from the hot water heater, so i think i'll add one there and see it picks up some debris. Then maybe a strong vinegar flush. We'll see if it works.
KandD
Jan 19, 2009
193
Hunter 40 Corpus Christi
ooo, reviving older post; always fun : )
I'm also having a minerals collecting in my strainer. I have AL tanks, and the water locally is like drinking rocks. I think I had a large deposit partially clog my out line on the tank last week until a winter storm shook it up. How strong of a vinegar solution would get the job done? It's 105 gallon tank, we go through it about every week or two (live aboard). It's not from my heater, the strainer is upstream and there isn't a heater anymore : ).
